Е какъв е той? Сподели с нас колега.
OBD II - конектор
Не съм го виждал на живо но предполагам че е това http://www.auto-diagnostics.info/sdi_interface .
Stefan Hadjov написа:Stoyan_68 написа:А някой има ли идея откъде да се сдобия със "специфичните" обд-ii кодове за фиат?Fiat Stilo 1.8 16V
Да, generic кодовете са общи за obd-II, но би трябвало в тях да са специфичните P1 кодове. Дали от FIAT са се съобразили (има само общи) или има и специфичниP1 не знам дали ги има в autodata-та.
OBD-II codes consist of a number of parts. Here is a sample OBD2 code:P0171Here is a breakdown of what each digit of the code means:First Character - SystemThe first character identifies identifies the system related to the trouble code. * P = Powertrain * B = Body * C = Chassis * U = UndefinedSecond Digit - Code TypeThe second digit identifies whether the code is a generic code (same on all OBD-II equpped vehicles), or a manufacturer specific code. * 0 = Generic (this is the digit zero -- not the letter "O") * 1 = Enhanced (manufacturer specific)Third Digit - Sub-SystemThe third digit denotes the type of sub-system that pertains to the code * 1 = Emission Management (Fuel or Air) * 2 = Injector Circuit (Fuel or Air) * 3 = Ignition or Misfire * 4 = Emission Control * 5 = Vehicle Speed & Idle Control * 6 = Computer & Output Circuit * 7 = Transmission * 8 = Transmission * 9 = SAE Reserved * 0 = SAE ReservedFourth and Fifth DigitsThese digits, along with the others, are variable, and relate to a particular problem. For example,a P0171 code means P0171 - System Too Lean (Bank 1). To lookup your particular code, visit our OBD Trouble Codes section.they’re the same as the fiat specific codes; and that library is much easier to find (because an AR library doesnt really exist, hence your trouble). i have a paper copy at home, but i’m sure you can find one in google.there are 2 sets of fiat specific code libraries, the preCAN and postCAN sets. if your car uses a CAN BUS then you need the postCAN library which is newer and includes more codes.
Stoyan_68 написа:Stefan Hadjov написа:Stoyan_68 написа:А някой има ли идея откъде да се сдобия със "специфичните" обд-ii кодове за фиат?
Както и да е, говорим за едно и също нещо с различни наименования :D В Аутодата специфичните не ги дават-изобщо не е много полезна по мое мнение.Изрових отнякъде тези (прикачените тука), би трябвало да са еднакви за моделите след 2000г, но са само р1ххх. За съжаление ги няма стойностите, т.е. в какви граници се изменят ппараметрите от-до.Прикачени файловеFiat Stilo 1.8 16V
Stoyan_68 написа:Моя ЕЛМ в момента е в колегата rosenmvr, така че не мога да пробвам всички софтове които си изброил. Обаче с PСMscan2.4.9 и Scanmaster PRO (windows XP обаче) стилото се чете. Моето еку е хитачи-това има значение. В англ. форум май хвалиха софта на Gendan, аз го нямам, но пробвай да го дръпнеш може да стане.
