Не, че нещо, но ей така да попитам :D
Код:
ECU ISO Code: 0D 07 02 97 0225.5.2011 г. 18:09 ч.CONNECTED TO: FIAT MAREA ’99 100 16VMagneti Marelli IAW 49F Injection (1.6)--------------------------------------------------------------ECU ISO code: 0D 07 02 97 02FIAT drawing number: 46750003 Hardware number: IAW49FHW002Hardware version: 00Software number: 4565-HCO Software version: 0000Homologation number: 000000ECU programming date: 02/02/1999READING ERROR CODES:Няма грешкиREAD PARAMETERS:Odometer: 151 975 кмVehicle speed: 0 км/чIdle RPM Desired: 800 об.Engine Speed: 806 об.Manifold Pressure: 313 mBarEngine Load: 8,750 кг/чBaro Pressure: 1 014 mBarBattery Voltage: 13,6 VThrottle Position: 0,2 град.Idle Actuator: 66 стъпкиGas Pedal: Idle Desired timing value: 5,2 град.Timing value: 0,0 град.Spark Advance: 4,5 град.Injection Time: 3,390 мсInjection Time Cyl.1: 3,466 мсInjection Time Cyl.2: 3,442 мсInjection Time Cyl.3: 3,510 мсInjection Time Cyl.4: 3,336 мсKnock Sensor Signal Cyl.1: 0,547 VKnock Sensor Signal Cyl.2: 0,547 VKnock Sensor Signal Cyl.3: 0,537 VKnock Sensor Signal Cyl.4: 0,517 VAir Temperature: 45 °CEngine Temperature: 80 °CLambda Sensor Integrator: 1,048600 O2 Sensor Signal: 0,273 VFan relay: Off Universal Code: Not Received A/C ON: OFF O2 Loop Status: Closed Loop Mixture: Lean Phase recognize test: Performed Data recording: In Progress Engine Overheat light: OFF Engine Start Permission: Allowed ECU Programmed: Programmed A/C Compressor: OFF Cyl.1 Signal: OK
