Грешка при ползването на търсачката - често ми се случва
    Could not insert search resultsDEBUG MODESQL Error : 1062 Duplicate entry ’2063074622’ for key 1INSERT INTO phpbb_search_results (search_id, session_id, search_time, search_array) VALUES(2063074622, ’e232b7c0ec62486a4214b3125b28377a’, 1353060724, ’a:7:{s:14:"search_results";s:1409:"47, 23741, 24843, 25102, 25475, 25899, 26279, 26341, 26450, 26617, 26767, 27412, 27652, 27882, 29045, 29073, 29169, 29211, 29885, 30147, 30246, 30389, 31760, 32017, 32125, 32307, 32649, 33125, 33851, 33950, 34463, 35023, 35108, 35842, 35862, 36066, 36364, 37707, 38022, 38066, 38817, 39131, 39443, 40169, 40272, 40472, 40961, 41068, 42743, 44112, 44481, 44841, 45283, 45937, 46179, 46408, 46557, 46665, 47258, 47398, 47842, 48349, 48475, 48855, 48867, 49812, 51425, 51730, 52659, 52739, 52777, 53326, 53471, 53480, 53498, 54471, 54624, 54781, 54785, 57565, 57601, 57741, 57841, 58067, 58423, 58746, 59212, 60313, 60533, 61877, 61927, 61952, 63480, 63654, 63700, 64580, 64769, 64838, 64886, 65345, 65364, 66115, 66295, 66319, 66775, 68072, 68506, 69663, 69764, 69978, 70206, 70251, 70853, 70922, 71548, 72100, 72453, 73177, 73437, 74133, 74277, 74526, 74621, 74710, 75053, 75679, 75827, 77183, 77214, 77223, 77610, 77980, 78091, 78412, 78948, 79271, 79375, 80045, 80715, 80969, 81350, 81482, 82110, 82274, 82547, 82894, 83082, 83394, 83438, 83525, 83778, 83967, 84052, 84067, 84140, 84396, 84438, 84754, 84810, 85300, 85327, 85369, 85463, 85568, 85760, 86360, 86395, 86609, 86636, 87018, 87392, 87796, 87856, 87991, 88361, 88403, 88501, 89016, 89037, 89530, 89633, 89642, 89652, 90637, 90930, 90965, 91344, 91397, 91593, 91662, 91739, 91845, 92371, 92509, 92548, 93097, 93334, 93390, 93683, 94071, 94090, 94422";s:17:"total_match_count";i:202;s:12:"split_ search";a:5:{i:0;s:7:"горивен";i:1;s:9:"регулатор" ;i:2;s:0:"";i:3;s:0:"";i:4;s:0:"";}s:7:"sort_by";i :0;s:8:"sort_dir";s:4:"DESC";s:12:"show_results";s :6:"topics";s:12:"return_chars";i:200;}’)Line : 715File : search.php това ми излиза , кво ае?
    Незнам как е дефинирана базата, но ми изглежда като да има такъв запис в таблицата или е свършила големината на int-а на първичния ключ.
      Airfan написа:
      Кво? Жоро на български може ли да ми го обясниш, моля те. Възможно е аз да правя нещо при което да се случва но го прави и на служебния и домашния комп.
        S_BANKOV написа:
        Airfan написа:
        Не е в твоя телевизор проблема.
          Използвай гугъл търсенето във форума:Натиска се бутона "Търсене" като полето пред него трябва да е празно
