Fiat Stilo Abarth????
Fiat Stilo Abarth
Wheelbase 2600 mm Track front 1518 mm rear 1512 mmLength 4182 mm Width 1784 mm Height 1475 mm Length:wheelbase ratio 1.61Ground clearance Kerb weight 1265 kg Weight distribution(Front) Fuel capacity 58 litresBore × stroke 83.00 mm × 90.40 mm 3.27 in × 3.56 inCylinders Inline 5Displacement 2.4 litre2446 cc(149.264 cu in)Compression ratio 10.50:1Fuel system EMPFiMaximum powerEC 170.3 PS (168 bhp) (125.3 kW)@ 6000 rpmSpecific outputEC 68.7 bhp/litre1.13 bhp/cu inMaximum torqueEC 221.0 Nm (163 ft·lb) (22.5 kgm)@ 3500 rpmbmep 1135.4 kPa (164.7 psi)Specific torqueEC 90.35 Nm/litreMaximum rpm Manufacturer FiatCode Main crankshaft bearings Coolant WaterBore/stroke ratio 0.92Unitary capacity 489.2 cc per cylinderAspiration NormalCompressor type N/AIntercooler NoneCatalytic converter Y.:: Just because I am unique does not mean I am useful ::.
www.cyxap.com
